My Buddy in Virginia sent me a DVD last yr from the Trike Fest that they have in Haspin Indiana.....I took it and did a little High Light Clip of it....I forgot all about it until I was cleaning up my Puter yesterday.....:rolleyes:
Anyway,,,,Thought you might like to see some of the fun we have....
TF 06
Bud Lights and Red Lights!!!!!!!1
GET IT RAGGG!!!!!!!
    • By OldATVowner
      any ideas how to correct
    • By T37Mark
    • By hunky
      Thanks for looking!
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
