everything sounds ok spark ok when it is out of hole exhaust has pressure and suction at intake but will not start or fire even with starting fluid cannt figure it out and can not find service manual download free do not know if timing is ok can not figure out how to line up marks with out instruction
I believe it will be on the left hand side as you are sitting on the machine. There should be timing marks on the flywheel. There should be a bolt that sits over top of the stator that you can take off and see the flywheel, there should be timing marks on the flywheel, there should be a "T" that shows up in the hole where the bolt goes, that will tell you that the motor is at TDC.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
