Just Add Dirt Events
I am new here, I have my own site/company named Just-Add-Dirt.com. I market specifically for off road ride parks and events (public invitation). I have a family of four and we all ride. We spend time to travel to specific events and or ride areas to have different types of riding and or terrain for the outing. I am currently sponsoring a race series, that has mud racing, and obstacle course, GPS treasure hunt, and several other activities to interest off roaders. If you have interest click on (untitled document) link below for the schedule, and visit my site for the specifics.
Jeff
Untitled Document
The University of Dirt, now accepting applicants, be part of a growing field of financial opportunity in a field of dirt. Don't miss your chance at a satisfying degree guaranteed to hone your skills in an exciting career of pressure washing. Freshman classes starting at the Rocky Creek Campus, Culloden, Georgia.
I spoke to the folks at Rocky Creek today, there is rain in the forecast for Thursday the day before the events, this should be PERFECT. The obstacle course is designed as extremely difficult and passable, the idea is to keep things moving slowly to test the operator skills without excessive speed, and ther will be mud. The GPS treasure hunt will be a hoot with more than 16 coordinates to enter and locate, $600.00 in gift certificates and LOOT awaits its finders. The mud race will be true mud, not a water race, so bring some extra parts, if ya can't sling it then don't bring it, this is designed to be a spectator event, racers will get what they get.
Sound too difficult for you racers???
Well the race and the park were in perfect shape for the event, there was plenty of everything, Thanks to all those who took the time and spent their money to come out and enjoy the event. There will be more, Bennett and the Creek are an easy choice to have fun on any weekend. I am jealous of those that live close to the Creek as they have the best riding anywhere with the nicest park owners that share their property for our use.......on to the next one.
Jeff
Just Add Dirt
  • Similar Topics
    • By FalloutBoy
      Hello everyone I'm new to the forum.
    • By jscarter32
      Greetings all, The bug has gotten me and just bought a 2002 non-running Yamaha Kodiak 400.  Hoping to find info here to get her running again!
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By DrtyGrlKristin
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
  • Similar Tagged Content
  • Gallery Images
