Help?? 2002 Kawasaki Prairie 650 Oil Type
tng6664
simply i got 2 different answers from local dealers,,1 says use 4stroke oil for wet clutch,,the other says it dont have wet clutch,but,can use wet clutch oil..the guy i bought it from used regular 20-50 castrol,what oil do i use,,ive asked on 3 forums,thats why i asked if n e one had one so i can find out what they use,,obviously it must work for them
You should to use four stroke ATV oil that has additives in it.
Valvoline® 4-Stroke ATV Motor Oil
Specially formulated to provide peak ATV performance and protection.
  • Extreme Condition Performance - Thermally stable formula maintains proper lubrication to protect engines under extreme conditions.
  • Wet Clutch Protection - Optimal frictional characteristics for high torque, smooth shifting and proper protection of the wet clutch.
  • Corrosion Resistance - Advanced additives help protect against water, deposits and other corrosive materials to keep engines clean.
  • Maximum Horsepower - Proper additive balance for maximum horsepower.
  • Minimal Wear - Increased anti-wear agents minimize wear from metal-to-metal contact.
  • Shear Stability - Shear stable viscosity improvers better resist oil film breakdown.
* Adjusted your thread title a bit, and added issue.
