97 Explorer 4x4 intermittenly doesn't work
Similar Topics
By alexwv1863
Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
By Gwbarm
By mfay1
Can anyone tell me where the fuses are on a 2005 Polaris Sportsman 400. The winch suddenly stopped working. I put a tester on it and its not getting any juice. Please help! (I dont even know if the machine has a fuse for that)
By 800CCBRAAAAAAP
I tested the stock OEM coil, and got 25ohms. But even after applying voltage, I cant get anything to magnetize to the coil Does anyone have a way of testing the 4x4 on-demand coil?
By BlueBowtie
Is it possible to put a motor from a big bear 350 into a timberwolf? Reason I ask is that I have a timberwolf with a bit of a rod knock, and I have big bear with a bad rear end and axle with a good motor. So, is it possible?
Similar Tagged Content
- 3 replies
- 3,995 views
Need info please... 1998 Suzuki 500 Quadrunner 4x4
By vonda flynn,
- suzuki quadrunner, 500,
- 4x4
- (and 1 more)
- 10 replies
- 4,733 views
- 8 replies
- 25,924 views
- 1 reply
- 2,647 views
- 16 replies
- 4,194 views
Gallery Images
