Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
-PupATV
I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
