took my 350 warrior to the shop to have it rejettted, after a week they called to tell me they dropped a valve. its has been a few weeks since but today i was looking at the carb and noticed the slide in the carb is stuck wide open. would this cause a broke valve, a canyon of a hole in the piston , a bent valve quater inch gashs in the cylinder head. and he told me it all happend at idle
If the slide was stuck wide open when that happened, it would not have been idling, it would have been running wide open. It sounds like they had it tuned too lean, or the motor was sucking air from somewhere causing it to run lean. Either way, you should be taking that thing back to that shop and shoving that Warrior up someones as*. If they broke it, they should fix it.
    • By mehim
    • By logray
    • By LCP92
    • By ebertz28
      Looking at 2 quads and need help deciding. #1 is a 2021 CF Moto 600 Touring with 69 miles, 2 seater with factory installed plow, windshield, backrest and luggage box with no warranty remaining  for $6500 or #2 2022 CF Moto 500 with 15 miles and a 2 year warranty for $6000?
