Similar Topics
By BOHUNTER
Hi all, I have just come into possession of a 85 lt230 shaft drive but I cannot find any clutch adjuster on it anywhere....
Can someone help me out here or do I have to replace the clutch...
Tia
By Gwbarm
Just checking to see which differential oil everyone is using: Valvoline, Lucas, Honda,Yamaha etc.
By Taksist
I am desperately searching for a rear propeller shaft (main drive shaft) for a Vitacci EFI 650 / YL650UTV-1. The dealership I bought it from saw me coming - it's been nothing but a headache! I need to replace the entire shaft but *cannot* track one down! Consequently, if anyone has some tips on reforming a deformed yoke (the part that holds the u-joint), I'm all ears!
I can give you pics as well as the whole story of how it happened, but since this is my first post, I figured I'd err on the side of less content initially.
By thatoneguy12345
Hello All,
Just got my hands on a project ATV. Its a 1999 yamaha big bear 350 2 wheel drive only. I thought I had a manual to diagnose everything, but the numbers are not seeming to match the manual I found online. I have replaced the coils based on the original diagnostics I completed. I can not seem to find an accurate manual for this bike. Anyone help?
I'm trying to get a wiring diagram that actaully matches the correct wire colors on this bike to assist in diagnostics.
Thanks!
By El_Guapo
Hi folks, im working on a kazuma Falcon 250 with has the ubiquitous 3 lug 8" wheels. have a set of polaris ranger wheels and tires that i would like to use on this little atv. they are the standard 4 on 4 bolt pattern. Any recommendations for wheel adapters to achieve this? (double whammy as the wheel track will get wider with adapters). cheers!
Similar Tagged Content
Gallery Images
