I have an 03 ltz 400 that has a crack in the left engine case right by the shifter. Wanting to know if that is a common problem with the motor? Thanks!
It is a common problem on any machine that has thrown the chain. Check the shifter shaft for marks on the top that look like the chain has gouged into it, also check to see if the shaft is bent. I would recommend getting that crack welded up, if the part comes off completely, you will lose all your oil and I'm sure I don't need to tell you why that would be bad. Also, a good case saver will prevent things like that, and are a must on any chain driven machine IMO.
Most machines come with a half-as* sort of case saver, but they don't work that well. A good quality case saver is worth it's weight in gold. Here is a link to the ones that Rocky Mountain ATV has.
http://www.rockymountainatvmc.com/vehicleFilter.do?prevVehicleType=1&prevMake=7&prevModel=65&keyword=&vehicleTypeId=1&make=7&model=65&applyFilter=Change+Vehicle&year=2003&navTitle=Drive&webCatId=9&navType=type&webTypeId=68&uri=%2FtypeDetail.do
Edited by DirtDemon
  • 7 years later...
Yes very common a lot of times the chain brakes if its not maintained properly. Or the shift shaft gets bent due to hard shiftig
    • By digrig
      Hey everyone,
    • By ButchM
    • By dkgg5755
    • By BillR94
      Thank you for your time
      Bill
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
