Anyone have any suggestions on gearing for the KFX450R it has plenty of low end right now I would like to get a little more out of the top end but don't want to loose to much of the low end either any help or anyone set there's up?????
Try dropping a tooth or two in the rear. Going up one in the front will probably be more than what you want. One tooth in the rear should give you a slight bit more top end, and you probably won't notice the loss of bottom end power. If you go down two teeth in the rear, you will notice a pretty decent gain in top speed, but you will also definately notice the loss of low end.
Thanks for the info I think I will try droping just one tooth in the rear I am looking at the Primary drive stuff they sale a sprocket and chain kit for a pretty good price anyone used this brand??
    • By noticon75
    • By toe420
    • By Callaway
