parts needed for 1990 - 2005 Suzuki LT160
Hi all you guys out there.
I have a 1998 Suzuki LT160 Quadrunner.
I need 1 10 X 24 lug nut stud
I need 1 used "hub cap holder" The cap holder goes on below the wheel hub nut.
I need 1 used "hub cap"
Let me know if you have something I need and how much you want.
USED not new.
Thank You,
Pumpkin472
Edited by Pumpkin472
acquired new information
Hi Josh, you "dirt demon" you,
1 bolt I need is called something, but I don't know what, but on the outside the lug nut screws on to it.
The cap is maybe called a hub cap? The cap holder goes on below the wheel hub nut.
I need 2 bolts that go from a arm on the frame, through the top of the fender and into the bottom of the front rack. I have no idea of the size or threads it would be.
Thanks so much for your reply
Pumpkin472
Here is a link to a parts fische, select your machine using the dropdowns in the box labeled "OEM parts lookup by model fit", once you are in the fische for your mache, you can select different sections of the machine and identify the parts you need. This site also has some of the better prices I have seen for parts online.
Babbitts Sports Center | Arctic Cat OEM Parts | Can-Am (Bombardier) OEM Parts | Honda OEM Parts | Kawasaki OEM Parts | Polaris OEM Parts | Sea-Doo OEM Parts | Ski-Doo OEM Parts | Suzuki OEM Parts | Yamaha OEM Parts
On the front wheel, you will find the cap as part #12 and the wheel stud that the lug nut screws onto as part #3. If you are looking for those parts for the rear wheel, they are #2 for the stud and # 10 for the cap, the studs are different from front to rear, but the caps are the same. If you look at the diagram labeled "carrier" in the dropdown, I think the bolt you are looking for is #4. I looked up the parts using the 1998 model year.
WOW! You really went out of your way to help me. Thank you so much. You are terrific!!!!!
I got everything but the hub cap. I don't want to have 1 shiny new hub cap, so I will try to find a used one. I had searched the internet for a rack and found nothing that looked like my "carrier". There isn't anything you can't find on the internet IF you know the name of it.
  • 4 years later...
  • Similar Topics
    • By 86096
      I have a 1985 Suzuki lt230ge with electric start.  It has a keyed ignition.  The key, once inserted will move to two positions.  There is a button on the left handlebar to engage the starter... so what do the two key positions do.  Anyone know???? I am looking forward to getting to enjoy this machine but I can't find a lot of info online about such a classic ATV.  Thanks in advance for any advice!!
    • By dlgg7
      I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ???
    • By gohndd
      Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
    • By Cheetah
      Hello,
      recently I removed my starter because it was to slow so before buying a new one I thought cleaning it. So I did and it did went much better.
      The thing is I replaced it exactly as it was but since then the starter goes freely like there’s no dentelywheels.
      Did I do something wrong ?
  • Similar Tagged Content
  • Gallery Images
