QUESTION,
1. I CANT AFFORD TO BUY A NICE EXHUAST SYSTEM and even the stock mufflers on ebay are way expensive how restrirctive is a stock muffler compared to most aftermarket ones? also i do have the stock head pipe just not the silencer.
2. on mine the pull start is broke and i'm not really worried about having it on right now since they arent cheap to replace. Anyways can i put a side cover frm a newer machine
on there to cover the area?
thanks
What is your budget??and the side cover would probably work i don't see why it wouldn't. You can pick up a pretty nice silencer and use your stock head pipe for around 180.00 and this will defiantly help gain a few horses the stock is pretty restrictive.
my budgte is pretty much nothing all i have is maybe 50.00 ,lol
i spent 40.00 on the front pipe itself.
they arent cheap for some reason
my freind has an hmf kit fomr his yfz 450 he isnt using he wants to sell me
If you can make the YFZ pipe fit, great, it will take a bit of fabrication to make it fit the only other thing I would be worried about is that the YFZ is a high performance motor with a bit more compression than the Warrior, which I would not consider to be a high perfromance engine. Therefore, the YFZ exhuast may not provide sufficient back pressure for the Warriors rather tame engine. Now if your friend has the stock YFZ exhuast with the baffle still in place, that may work if you can get it to fit. Also ebay is your friend. These are the cheapest ones I could find. One you can buy now, bidding ends soon on the other. Nevermind the years, they are all the same. The buy it now one is a full set, you can sell the header that you already have to get some of the money back. Keep checking, you never know when a great deal is going to pop up.
http://cgi.ebay.com/ebaymotors/Warrior-EXHAUST-PIPE-2001-yfm350-89-04-350-LOOK-/150463861039?cmd=ViewItem&pt=Motors_ATV_Parts_Accessories&hash=item230858512f
http://cgi.ebay.com/ebaymotors/1989-Yamaha-Warrior-350-Exhaust-and-Exhaust-Header-/330448582919?cmd=ViewItem&pt=Motors_ATV_Parts_Accessories&hash=item4cf0453907
Edited by DirtDemon
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
      Hello there
    • By Callaway
    • By Gkb
      Need ideas for all aftermarket accessories for my new atv
    • By sunn
      Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
      My heat gun shows after 15 minute ride in ambient 91 deg temps;  690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler.  The right side plastic (where wife's leg would touch) was showing 175 degrees.  This is rediculous!.
      As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
      What is everyone doing about this problem?  Is there a replacement muffler to eliminate this issue?
