There are access holes on the front and back of the cylinder head. Take the cover plates off and you will see the end of the rocker where it sits on the vavle stem. At the end of he rocker arm you will find a small set screw with a nut around it. Back off the jam nut and turn the center screw to adjust the valvle lash. When the lash is set, hold the set screw still and tighten the jam nut. Double check the adjustment when you are done. I don't know what the lash settings are, you should be able to get that info from a dealer tech. However I think it is alway best to have a repair manual for anything you work on, it will also have the valve lash settings in it.
    • By Jdeaton011989
    • By davefrombc
      1992-98 Yamaha YFB250 Timberwolf 2WD service manual
      View File Service/Repair manual 1992-98 Yamaha YFB250 Timberwolf 2WD
      Submitter davefrombc Submitted 08/06/2017 Category Yamaha ATV
    • By Tim Keiper
      I know this is long shot but, would anyone know where I can find a good used or new original carb for a 2000 YFB250 Timberwolf 4x4.
      Every Yamaha dealer I look at on line, it says not available. I have tried 2 aftermarket carbs, and they suck, I would like to find a used original if possible.
      And I have another question. Everyone says about Chinese aftermarket stuff is junk, Where does the aftermarket stuff come from when the original in from China ????
    • By Tim Keiper
    • By PvtTarget
      Will not go into 1st but if ya go past will go into maybe next gear. Will not shift into reverse. I have see others say that the shift cam assembly dowel worn or fall out. How do I get to this? Do I need to break case in half?
      thanks for your help
