I am Tired
By kiriyaaoi
Hello everyone, I just picked up an 02 LT-F250F the other day and have been in the process of tearing it down to fix some stuff- one of which was the cylinder base gasket leaking like a sieve. Well, I know why that is now, and I also discovered that someone had been in there before. I didn't take pictures, but it looks like it was probably run low on oil at some point, the cam journals and the "bearings" (for lack of a better term) in the head and the valve cover are totally wiped out, very deep grooves. From what I know it's very difficult to repair aluminum in this way, so I'm trying to figure out where to go next.
1. Have someone grind down the head and valve cover and fit actual bearings in since the aluminum is screwed, and have the cam ground down to match. I have no idea what this would cost.
#1 I was hoping someone might have some advice on, but #2 seems like it'll (probably) be the more cost effective option. However I'm running into some difficulty, it seems like the 2001 and 2002 models specifically use a different head part number, 11100-19B10, instead of 11100-19B01 like for all earlier models. What exactly is the difference between them? There are obviously far more of the earlier heads because it ran for over 10 years. Are they actually interchangeable? I've also noticed there are heads from the LT250EF that has 4 valve heads but also otherwise look identical. Would those work as well possibly? I'd like to not have to drop $500 on machine work or new heads on a $1300 quad that I'm already putting a bunch of new parts on. Oh, and it has a new piston and the cylinder itself looks pretty good too, as I said someone was in here before me.
By cfauvel
there are two part numbers that come up for the voltage regulator
32800-44D21 model Y
32800-44D31 model K1
I don't know which one to get .
how do I know what model the ATV is?
By deckeda
The story goes, my daughter "did something" to the ATV and now it won't start. I suppose these things aren't kid proof.
All I know is that the Neutral light stays lit no matter what gear, and subsequently the starter won't turn. I briefly Googled but only came across symptoms of the Neutral light never lighting up.
I have downloaded the service manual from this site (thank you) but don't quite know where to attack it first. Thanks for reading.
By 4tracker
Good place to start out is at St Helen Mi. campground or Trails inn motel, both on the trail head across the street from one another, with all the amenities needed in town there for your stay like an atv parts dealership, gas. restaurants, liquor store, drug store, hardware all within a blocks distance away. From here you can head E. towards Houghton lake Mi. trail system or West to West branch or N. through Clear lake then onto city of Mio trail system. So many great places to check out along the way heading north fro there, like Clear Lake, with their Bar and grill, corner store, gas, lodging, Ambrose lk. atv campground near by, and with so many surrounding trails there too, with hill climbs! Then after leaving Clear lk. head up to wagon Wheel N. of Rose city rd. with dozens of trails scattering the hill side there called the Rose city oil fields. Then on up N. to the gravel pit for a little play time, before crossing M33 at the Pink store for gas and snacks. Leaving there to head up to Mio's Bull gap, either on the west side (shortest rout) or you can do the half Bull Gap trip through Mac lk. Campground heading N. to Bull Gap or the long way around from the Pink store traveling on the 50 mile loop that passes Bull gap on its way back to the Pink store. Make sure you take along the printable Mi. DNR atv trail maps with you, to help guide the way, along with the other areas I just mentioned, maps.
If your looking for a friend to ride with and show the way with , over 50 nearer my age and interests, contact Email: [email protected] for more info. I'll be more than happy to ride with you! Thanks Steve
By MeatGrinder
I have a 98 King Quad 300, a rock went through the stator cover on the left hand side i have found a cover off a 2000 for a decent price just wondering if there were any changes that would make the cover off the 2000 not work on my 98.
