Newb question/opinion
By Gtc4d
Thanks.
Todd
By jordan_ATV
By dropze13
Hi,
I am recently new to quads and want to learn about the basics and know what i need in case i buy one this coming winter, i am currently looking at quadzillas due to them being available where i live and when looking a better choice than a yamaha raptor as i have a couple friends who rebuilt the engines on them 2 or even 3 times and always had somekind of problem.
What do i need to look for when buying a quadzilla engine wise and what do i need to check before purchasing one. I heard the quadzillas are reliable and are not a bad quad overall and they do not look bad either.
Also what are typical problems with the engine and what do i need to regularly check / maintain to ensure i can ride with peace and not need to worry about anything breaking, how much do they also last in terms of miles and ride time ( i know this depends on the use, i will mostly be doing off road and some street use so around the 40-60 mark if they reach that )
And to service / maintain them what do i need before hand, what oil, what sparkplugs and anything else such as coolant for summer / winter use.
And if there is any aftermarket parts / components that i can invest in please let me know to explore my options.
Thank you very much and i appreciate the help which i may get and hope to get into the quad scene soon!
By Chucksta
Any ideas?
By prdicon
South Florida.
How much it worth?
Pros: looking decent.
Cons
No brakes.
Front wheel bearings are shot.
Idles, but sometimes will shot off. Most likely when cold.
Gas smell and little bit steam in the air filter box when I started it.
Display screen won't work.
Tires are dry with cracks.
Not sure if has title, I will check and update.
How much do you think it worth?
