Guest spamble11
hi
some kid wrecked my LT-300 into a pond.......upside down. don't ask. anyway, i think i have everything back to normal except, when the quad idles the exhaust pipe get cherry red, pretty quickly. i assume it to be a mixture problem. it starts and runs fine. any thoughts? if it is mixture, how do I adjust it?
one thing I should tell you is that a friend took off a cable screw from the bottom of the mikuni to let water out (which was wrong). anyway, i have put that back in the carb but, don't know what that is or whether that needs to be adjusted too. (it's a black phillips head screw that has a cable that goes to the bottom of the carb).
help me, please.
tx
Edited by spamble11
I think the best place to start is take the carb off, take it completely apart and clean everything. The pilot mix screw is usually on the bottom of the carb just in front of the float bowl. Also, if you haven't done it already, the gas that was in it when it was submerged needs to be thrown out and clean the fuel tank out. I would also run some water through the fuel lines and petcock. The cable you are talking about is the idle adjustment I think.
Guest spamble11
tx DirtDemon. I removed all of the fuel and cleaned everything with drygas. i think you are right about the idle adjustement. i found an exploded view of the carb and it shows as an adjuster assembly. i'll try removing the pilot mix screw. I assume this is the fuel/air adjustment? if so, i'll try to richen it up until the pipe is't so toasty. any idea of a range for adjusting that thing?
tx again.
On most machines the setting is between 1 1/2 and 2 1/2 turns out. This only affects the air fuel mix on the pilot circuit, which controls throttle positions from idle to about 1/4 throttle.
Guest spamble11
do you think that could cause the red pipe? should this be adjusted while idling?
it does occur at idle and pretty quickly. i would like to avoid taking it off again but, i may have to. i'll also hit it with carb cleaner, for what it is worth.
tx so much for your help. i'm better at breaking them than fixing them.
Guest spamble11
i changed all of the fluids and I don't think the muffler is clogged. some watter came out at first but, that's all. I have stood the wheeler almost straight up and down using the winch and ran it for a long time so the muffler should be empty. plus, it runs well so I don't think it's obstructed and the way it heats up, any water in there should have evaporated. i may have to break down the carb as demon suggested. i didn't completely tear it down the first time. maybe I can get away with some carb cleaner and mixture adjustment. although, I don't want to touch the mix as it ran well beforehand and that really shouldn't have moved in the "incident".
If you didn't take the carb all the way apart, it would be best to do so. You want to make sure there is absolutely no gummed fuel or any other debris clogging any passages of any sort. Since it sounds like the machine was pretty well submerged, there is a good chance that there is some foreign debris floating around in there. Spraying carb cleaner in it won't cut it, you need to take it off and COMPLETELY disassemble it. Make sure no passage is over looked. Take the pilot screw all the way out and blow compressed air through the curcuit. You can use compressed air in other spots, like the float bowl vent tube to make sure there are no blockages. You are correct about the pilot adjustment, if there were no problems before, and you never messed with it, then the problem is elsewhere. Most likely inside your carb.
Guest spamble11
Ok fellas, took carb out and apart, cleaning it with Castle's Shop Solve. Put it back in, adjusted idle, runs like a top....... wait for it...............and yeah, the head pipe STILL turn cherry red at idle.
Should I try the air/fuel mixture adj? is it possible there is something in the muffler? I don't see how, it runs great, just heats up. Scratching my head now.
I'm dumping the oil again, it's looking grey and sludgy. must be some water in there that I didn't get with the first oil change.
any ideas?
tx for all of your help
The condition of your oil, could be causing your machine to run hot, if there is enough water in there to make the oil look like you described, then the viscosity of the oil will have been severely reduced. This ofcours will increase friction, which turns into heat. I would start by making sure the crankcase is clean and dry. If the problem persists after the oil issue is fixed, I would probably say the following.
I guess it would be a good idea to ask if the machine is completely stock with the airbox and lid unaltered? If there have been any alterations to the machine, a jetting change may be in order. If the muffler is flowing well, seems unobstructed and is not excessively loud, then I would say it is ok. Also, I assume that you never noticed the glowing pipe before the pond incident, do you know for sure that it never did that before? Some machines do get a slight glow on the head pipe that you can usually only see in the dark or really dim lighting, this is normal. Also, since the machine is air cooled, it will tend to run hotter if it is not moving, since there is less airflow running over the engine to help dissipate the heat, you are relying completely on the fan (if you have one) to move air around the motor. Have you confirmed wheather or not the cooling fan is still working? Does your machine have a cooling fan? It was an option on those machines. If it was ruined in the incident, this could be the cause of your problem. Just to err on the side of caution, I would try adjusting the pilot screw just to make sure. Turn the pilot screw inward until the machine starts to run poorly. Then start backing the screw out until the idle reaches its highest point, if needed adjust the idle back down. This should give you a proper air/fuel mix on the pilot circuit. Also, look at the plug, the color of the insulator is a good indicator for judging the condition of your jetting conditions. Good luck, I hope you get this figured out soon.
Edited by DirtDemon
Guest spamble11
DD,
Thanks again for the help. I agree about the oil, it certainly isn't doing what it is supposed to if it is grey. i'm going to change that, at least once, before I do anything else. What do you mean by the crankcase clean and dry?
The bike is stock, no alterations at all. Muffler flows well and bike runs great, just hot. So I agree, I don't think the muffler is a culprit. Besides, anything in there would have evaporated by now and it's not like the thing was buried in mud, just water. The pipe never glowed before this and I have run it inside the garage so I would have seen it.... i think. Also, it only take like 3 min of running to get it cherry red, there is definitely something up with the bike. There is no cooling fan and it is air cooled but it does have the oil cooler and an indicator light (last I knew it worked) for when the oil temp gets too high. So far, the light has not come on.
I'll change the oil (flush the cooler too) and adjust the pilot screw and see what happens.
If anyone out there has an infrared thermometer and can tell me the approx temp of their head pipe after running at idle for 1, 2 or 3 minutes, that would be great!
tx again.................. the saga continues.
By clean and dry, I mean no water in it for the oil to mix with. You may want to let it sit and air out for a while after draining the oil, let every thing get a chance to pool up and get out the hole. Maybe it wouldn't hurt to blow some compressed air in the hole with the drain plug out to help. Good luck.
    • By Thekevinjb
      thanks
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
