My dad said if I wanted a four wheeler I had to build it. Well it took me over a year to do it but now I am having troubles with the carubretor. My dad and I tried to rebuild it and we took our time doing it but the problems we are have are: we are getting exhaust blow out of the carburetor and exhaust out of the tailpipe it back fires at a high rpm and when we put the air box on the carburetor we have no acceleration. We have stop at a couple dealerships but they don't work on anything as old as my 88 warrior and have no idea. Can anyone help please. You can email me at [email protected]
Tags: Rebuilt Engine Carburetor
    • By Cj Winds
    • By TomJulio
    • By Jason39
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By austinfuller22
      i have a lt 230 and the e start isnt working but i dont know why
      can i have some help
