By HoldenBoy
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
By TravisCr
By kawasig
By WyattLemke25
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
