plug the hole on one side of the bar/grip and blow compressed air into the other side and slide the boot off with a litle bit of work. if your headlight switch is causing the drain it would have to pull power through your headlight because light switches are classed as a ground side switch. therfore you should see some kind of light from pod. I would start by testing all of the aftermarket parts if you have any. I would suspect hand warmers our winch if it is hard wired. hope this would be of any help.
your friendly neighbourhood mechanic.
  • 6 months later...
    • By vaneleus
      any ideas how to correct
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By Olchap
      Thank you,
      Olchap
