DD says you should get a repair manual, they are a must for those of us who work on our own machines. There will be important info in there like torque specs, wear limits valve lash specs... It will probably even tell you to torque the primary pulley center bolt to 69 ft/lbs, and the cover bolts to 113 in/lbs or 9.4 ft/lbs.
    • By RadRob
    • By Coyote251
    • By Ejwill
    • By KdlH
      Hello.
      I'm new to the forum, I live in the UK. I have just bought a 1995 Yamaha Moto 4 350.
      Generally the condition isn't too bad (I paid very little for it!), it looks quite original and all the plastics are quite good. The bad bits are no brakes, the rear axle bearings are shot and the transmission won't shift through the gears properly.
      I'm not planning on a full rebuild but I would like to sort it out a bit. The transmission is my main concern. If anyone has any ideas on what might be the cause I would be grateful. I can explain what's happening in more detail if required.
      Thanks everyone,
      Kester
