Not hard at all, there are two switches located on the front of the motor beside the oil filter. The fan switch and the oil lamp switch, I believe the fan switch will be the one on the left as you are looking at the front of the motor. I would inspect or replace the gasket too.
    • By Fonne
      Hi
    • By Arizona
    • By middlebrookgt
    • By C2INS
    • By middlebrookgt
