Welcome to QUADCRAZY! Usually there are little marks like dots on the sprockets for the cam and crank. Hopefully someone here has a diagram for you. Might look something like this:
  • 5 weeks later...
pull the top head off and you will get to the cam and the timing chain. make sur the motor is top dead center on compression stroke. the on the cam chain gear is 2 lines . line them up with the head and it should be timed.
    • By Thekevinjb
      thanks
    • By RadRob
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Mhatayas
