By jordan_ATV
By dkgg5755
Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
By TravisM
2001 bayou 220 KLF220A
I'm at a loss here. Thanks.
By Tuzz
Bucking started about a month ago and works ok after 1/2 hour warmup. Today while working on it i discovered that if i put the ignition switch in LIGHT position it runs fine right from the start.
I'm stumped! Any idea why this could be?
By picriver
new ignition switch
four wires - green, red black, black with white line
atv four wires - pink, pink with white line, black, red
which is attached to which, please and thank you?
