Ok, i have a 2007 polaris predator 500 and it needs an engine upgrade. i already have a trinity stage 4 exbaust, 15 tooth sprocket and shaved fenders. its not enough juice, so im looking into the 558 bbk. the kit will come with a 12:5 compression piston, sleeves, pins and the whole 9 yards. ive looked up you need to run a carb from a trx450r, is this true? and does the carb have to be year specific? how much would it cost for everything to be installed? and can you run 93 octane pump with this big bore?
The labor to install that kit will probably cost more than the kit itself. Call a shop and ask them to give you a quote. You can run pump gas on a 12.5 : 1 piston, but it might not be a bad idea to mix a little race gas in there to keep temps down and avoid any pre-detonation. I know nothing about what kind of carb you should run, if the carb from a TRX 450R is a couple millimeters bigger than your stock carb and it fits, that might be your ticket. You may want to get ahold of a place that builds Polaris race motors and ask them for some info.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By mehim
    • By logray
      Hi all,
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
