I got the quad from my dads friend and he said it ran good just been sitting awhile. It will start on starting fluid and kinda idle awhile but as soon as you give it gas it bogs down and stalls. So i thought it was the carb took that apart and cleaned it up and still does the same. Its gotta be a fuel problem. Could of the fuel pump dried up and isnt pumping right? Or any other ideas any help would be great. Thanks
Fuel pump is a definate possibility. Did you drain the old gas and put new fuel in? If not, you will want too do that. Also, did you take the carb completely apart and clean every single thing, you need to get all the jets and other holes completely cleared and take all the metering screws out and clean the circuits they control. Also check the fuel valve, it could be clogged too.
Ok thanks im going to mess with it some today and yea i drained the old gas and put new in ill check the pump and valve today and see what i come up with thanks again
    • By Thekevinjb
      thanks
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
