i bought a 2004 raptor 660 and the guy had jeted it and it would start but bog down so i replace the jets the jets were 140 but everything was stock so i put stock jets back in. well it starts good and idle great. but when u put in gear and try to take of it has no power it seems like its in neutral, its goes but slow i push the gas and all its doing is reving up. i shift gears, all gears go in perfect but still no power... HELP!!! plz
almost sounds like your clutch is wiped out,i would start there,if u need a service manual for your raptor message me your e-mail address and i will send you a link to a manual you can download....good luck with the rappy...........i also have two 660 raptors
That's a good point MIKEL5469...:yes:
with engine off try put the gear and push it if its spins ease on second gear then its a clutch .try adjust it ,but u have make shore to remember how it was in case it not helps.
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
