gasket valve cover DS650 2001 popped out whats worng????
By Spritee1
not sure where to look next
By hardcastle
By Topendcol
First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
Col
By Werewolf
By SCmasterTech
I bought a 220 for my daughter and after riding for while it cut off and wouldn't start back up. Found the cam and rockers completely destroyed. When I replaced the head and got it running I checked and had no oil pressure. Pulled the side cover and the oil pump was missing the plastic gear. There were no pieces in the anywhere to be found. The side cover didn't look like it had been off in a long time. I wonder how long this thing was run without an oil pump. Put a new pump on it and its been running great.
