I just bought a used 04 LTZ. I have been riding it without incident for the last few months and then i was riding it kinda hard up some switchbacks in the mountains and the temp light came on. I stopped, put my quad in neutral and the fan never came on. I have heard it come on in the past. Any ideas?
Thanks,
Amy
without putting a multimeter on it its really impossible to say what the issue is. I cant get the fan to come on with my TRX. It will come on if I jump the sensor to a ground though. Leavign for the dunes in 3 days I just made a quick jumer from the temp sensor wire to ground so the fan runs all the time. It will take longer for it to warm up I guess but thats better then the oposite. I'll pull the sensor after vacation and test it.
if you jumper the sensor to ground then you are bypassing the sensor or creating a better ground. try pulling out the sensor and cleaning up the mating surfaces. or just replace the sensor.
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By wilmpie
      hi everybody
      thanx in advance
      any ideas how to correct
