i have a 2005 raptor 350se with a K&N air filter and Baffle removed from stock exhaust and i have a aftermarket cdi
i was wondering what i should jet it to right now its stock and when i fisrt start it up and give her some gas she pops so i need some recommendations on jetting
I would think it would need jetted pretty close to if you had a pipe on it... my 02 warrior was running a HMF full exhaust and i was running around a 148-150 so probably one or two under that... If i remember i changed the clip position one notch and went one up on pilot jet... I think i still have my jet kit from when i had my warrior... Should be the same carb and jets if you need some... All of this will also depend on your elevation...
well im not for sure...I think they are jetted a little richer than my warrior was... I was at 148 and i had open air box and full exhaust.... ill do some more looking and c what i can find... What is the stock jetting on them??
Edited by jigolbeep
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
