By NZrider
By ethie
Hi All
not sure where to start
By Tuzz
Bucking started about a month ago and works ok after 1/2 hour warmup. Today while working on it i discovered that if i put the ignition switch in LIGHT position it runs fine right from the start.
I'm stumped! Any idea why this could be?
By DarkRider
By Am2007
Hi everyone,
owner manual
service manual
engine manual
I have the first 2 but i can not find the last one, part number 219100232. If someone can guide me where do i find the oil strainer so i can clean it i will appreciate it. im going to do an oil pressure test tomorrow to check how many PSI i have, just to make sure.
