decided to try to cross the river on my King quad 700 needless to say I didn't make it rolled a few times and ended stuck up side down in the river under a tree got it out and got it to start been flushing oil through, and changed oil filter but still has no power could some please help tell me anything else I can do
Moved thread to Suzuki ATV forum.
If you sucked water into the motor while it was running, alot of things could have happened. Bent valves, blown rings, bent rod, cracked/broken piston. First thing I would do is a compression test. Change or clean all filters, drain and flush the fuel tank, install a new plug, check all wiring connections and any enclosed electrical components. Make sure everything is dry.
    • By docdoug72
    • By Thekevinjb
      thanks
      The ATV Motocross National Championship (ATVMX) Series, an AMA National Championship, hosted its fourth round of AMA Pro ATV Racing at Lake Sugar Tree in Axton, Virginia on Saturday, April 26.View the full article
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
