colorado 14'er tour
By quadcrazy
Trail System Deep Dive
Final Thoughts
Visit Pine Mountain ATV Park
By mga
So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
By westomatic
Hey all,
My name is Weston and I own a small engine repair shop in Pueblo, Colorado. I've only been repairing engines for 2.5 years so I still have plenty to learn. I look forward to learning from you all and pitching in on problem-solving when possible.
Thanks for the add!
By Mesa_John
Semi went to the dark side from only two wheels about 2 years ago with the purchase of a CForce 1000 Overland. Then yesterday, I fully dove in, purchasing a ZForce 800 Trail. For the past 25 years, I have only been a Single Track, Enduro, Adventure and Sport Touring motorcycle rider. But upon moving to the Colorado Western Slope and finding thousands of miles of two-track, I just had to have the 50" experience as well. Also, there is the fact that the wife and I (she also rides motorcycles), turned 57 years old this year and we just don't feel as confident and comfortable tackling the challenging single-track stuff like we use too. These four-wheeled critters will allow use to keep exploring the remote and lonely spaces we love.
I look forward to reading and learning more.....
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
