By kawasig
By Travis_Smith
By mga
I get it, turn counterclockwise will decrease, turn clockwise will increase. My question is what exactly am i increasing or decreasing? Is it clutch pressure? In many videos i've seen it's always "turn counterclockwise" until you feel resistance then back off. Why is it always to decrease?
I'm just curious as to what exactly is going on when i turn that screw right or left. And, since there's no manual clutch to engage or disengage, what is going on inside?
Reason why i'm asking is while going down a hill in 1st gear, it appears to pops out of gear, but no neutral light, and if i stop, it's in 1st gear still. BUT, (always a but) if the engine is warmed up, it stays in 1st gear. The hill is too steep to use any other gear, so 1st with the brakes is the only way to go down.
By Norseman69
Hi. I just bought an lt230 1993. Ive started buying parts for a full rebuild. But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed. I was wondering if anyone have one and Could measure how far out the pegs are. Like the peg the brake is put on and then peg outside of it. And the one lower down. So i can recreate them.
