bought a non-running 425 magnum from a friend. has not been running for 2 years. last it ran the exhaust pipe got cherry red... hot enuf to partially melt the heat shield. engine was turned off and allowed to cool. wouldn't re-start. new spark plug didn't help. haven't tried much to fix it yet... looking for a good starting point.
ebay has carb kits for around 35.00 give or take. I have to swap out cams on the 425 and 500 often but that wouldnt make it hot but somthing else to check. If you pull the valve cover and spark plug kick the motor over and the rockers should be raising the same height the front rocker is the exhaust and thats the one that goes and obvious when its worn out.
Good luck Todd Polarisatvrepair.com
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By TomJulio
    • By marlon smith
