My king quad neutral light will not come on it worked one day and the next day it didn't. I have checked all the wires. I pulled the neutral saftey switch out. When in neutral it doesn't have power but if you put it in reverse you podo have power on the switch. It will crank if you hot wire it. What could be wrong with it?
    • By OldATVowner
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By sandman001
      This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
    • By Rockbottom
      any ideas how to correct
      thanks ahead
