My king quad neutral light will not come on it worked one day and the next day it didn't. I have checked all the wires. I pulled the neutral saftey switch out. When in neutral it doesn't have power but if you put it in reverse you podo have power on the switch. It will crank if you hot wire it. What could be wrong with it?
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By sandman001
    • By wilmpie
      hi everybody
      thanx in advance
      any ideas how to correct
    • By Adamb2025
