I don't water ride but the previous owner never did one ounce of maintenance on this machine. I t does run and drive out ezcellent.
I agree the bearings are going bad on the left side. I just inspected it further and I also have up and down play. I just bought this machine last week and had to replace the right front bearing and front brake pads. The left front bearing was like new upon inspection. No foreign particles in there or water sign.
Any body pulled the rear bearings before on an Eiger? If so can you advise the proper steps.
My thoughts are: Go rent a slide hammer puller and buy ret ring pliers. I believe it will be fairly easy like the front bearing was.
thanks Tacomaj1, Manchester, Tn
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By Monster12ptBuck
      What are everyone's thoughts on the CFmoto Brand ATV? I can get everything I want for a fraction of what these big brand name wheelers are charging. TIA for your input. Please let's keep this nice and clean Peep's
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By jashadams
      So I installed a new shock on my 125 yesterday sadly it wasn't adjusted right I took it off to adjust it tried to install it again today and it no longer fits I loosened the nuts on the spring again and it still won't fit idk what I'm doing wrong when I try to install it but I'm lost any tips or videos would be great thanks.
