By logray
By Shorty51
By sandman001
By quadnut20
By sunn
The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth. I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale. Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal. The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down. RNG would not tell me what the spring force was.
I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM. Note; idle RPM is approx. 1600.
I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information. What gives here? Anyone with experience to share?
