    • By middlebrookgt
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
    • By Clint123
      Hi All -
      My son and I went in halvers on a 2006 Kodiak 450 recently. We rode it some, and realized it is not charging the battery. I pulled the rectifier off and saw the plug was jacked up, the DC hot wire was not even making a connection. So, I thought that was the issue, but decided to test rectifier and stator using my multimeter while stuff was apart.
      The rectifier tested bad using the technique I saw on YouTube here:
      I got OL on a diode test when I should have been seeing .2-.8v on one of the tests so it is bad. So, I will be getting a new rectifier and fixing the wiring/plug.
      While doing that, I also tested the stator. The stator tested with zero ohms when checking resistance between the three white wires, and I think I should have been seeing at least a little resistance, .2-.9 ohms. I did a ground test and it was good. Also, I started the bike and checked A/C voltage on all three wires and it looked OK.
      My question is, do you guys think the stator is bad with the 0 ohms resistance? I am a little confused since I see A/C voltage.
      The wires are clean and it looks like there is a new gasket in place, so I think previous owner put a new stator in at some point. Also, the rectifier looks newer, not as dirty as rest of bike. I suppose he may have put in a cheap amazon regulator/rectifier and stator but not sure.
      Clint
