the mojave is a 1999 it will start up if you kick it forever backfires and then dies after the motor warms up it has gas running back into the air filter i cleaned the carb do i need to just rebuild it or does it sound more like it needs a valve adjustment if so does anybody have step by step instructions on how to adjust them
agreed also...but what was it doing before you cleaned the carb? Was it getting gas in the airbox then too?...I have a copy of the service manual from an online source if you need it.....send me a PM if you want it and good luck AND...welcome to QC!!!:wink:
When you had it off did you take it apart or did you just have it soaking in carb clean? If it was just soaked in carb clean you wouldn't have solved a stuck float. To fix a stuck float it will require taking the bowl off.
Taking the bowl off isn't advisable if you have no clue what your doing in there. If you have no clue how to do the work found someone that does know about the float.
i took the bowl off took jets out float off cleaned everything really good put it all back together i have cleaned many of 2 stroke snowmobile carbs this is my first try at a quad is it different and how would i get the seat to sit in there right
When you have the carb off and the bowl off. Have the float and needle installed and hold it upright like it would be on the quad. Now push the float up and make sure the needle is moving up into the carb. And when you let go of the float the needle should come back down.
The needle may not be stuck but maybe the little tab on the float needs adjusted. It may not be pushing the needle up far enough to stop the flow of fuel.
    • By realpilot
    • By OldATVowner
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
