ok i have a 2008 700 acrtic cat efi.. i was ridein it came back to camp site. for only a few mins got back on and went to turn key back on and no power to dash box or motor.. turn the key to lights and they came on.. what i have tryed is unhooking the battey for a hour and hooking it back up but still no power to anything but light. and its a new battiey and even ck to make sure that it was not the prom, it wasnt. i really dont want to put it in the shop and pay 500 just for them to tell me whats wrong and i have to pay more for the part and so on.. maybe someone out there has had the same thing happen or knows what it maybe.. like one of the two back boxs under the seat...what i was thinking.
does it have a fuse box ? if so i would check them.. i done work on many arctic cat quads so im not really familiar with there electrical system.. i would also just check to make shure all the electrical plug connections are clean and making good contact...
Besides the fuses and other easy stuff, make sure you have power to the ignition wire on the coil (Under the seat)
Check the front of the quad right where the steering stem goes down from the pod right around the metal clip for wires that have rubbed thru. This is the easiest place to start.
If that doesn't work pull the rear plastics and check for an ignition wire rubbing on the frame right where they come from the fuse box and wrap around the frame to run along the chassis. This is a known problem and the most common fix.
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
