QuadBoss Pile Driver ATV Snow Plow Review
This is a review of the QuadBoss Pile Driver ATV Snow Plow system, mounted on my Yamaha Grizzly 660 ATV. I’ve used other plows before and was excited to get this plow on, but the dilemma of no real snow in the part of New York where I live, made my anxiety grow, as I wanted to get out and move some snow! Well we finally got a few inches, not really a massive storm like I had hoped for, but it will have to do…...Read More
I think the review was great but that plow needs a little more weight on it.
If you are referring to the bouncing around...lol...you don't know my driveway, it's a mess with rocks sticking out all over, that's why it was hopping around in the video. You'd need a highway truck plow to smooth that out....lol.
We're going to lay down some material this spring hopefully. The plow works great, just waiting for some more snow to use it. :yes:
Just an observation, I am sure the driveway has alot to do with it. People have been looking for a down pressure solution for ATV plows for a long time but the truth is that with the down pressure all that bouncing force is transfered to the quads frame.
Other than that it looked really easy to install and use.
    • By Need-help-with-quads
      So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
      So I have an 89 Yamaha moto 4 250cc and when I ride it, itll get hot after like 10-15 mins and then will just die and turn off.
      It's has new carb rebuild, new air filter, new battery, new spark plug so I don't think it's a crack in the spark plug
      Can anyone help me?
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
    • By DarkRider
      Hey Everybody,
      Some of the features I tend to like best  (aside from durability and reliability)
      Durability is how long I can go without something breaking. OR how often things break with seeming not much of a good reason. Reliability is about the on-trail experience of having everything work properly as designed (i.e. Starting up and being able to get going without much issue, the 4wd drive engages without quirks, I can park it on a hill when needing to help someone else without worrying it'll roll away, etc) My Brute Force 750 is a perfect example of why Durability and Reliability were rated so differently. With durability, I really never felt like I've had anything break on the thing that was really from riding it. Which is great in that regard. But all of the things i've had to fix on it seem more so in it's design. The infamous KEBC code on the dash that refused to go away even after completely cleaning and lubing the KEBC and confirming it functions properly. Hard starting issues. 4WD requires you to roll about 10 to 15 feet to engage, so if you get stuck in 2WD, you're in a pickle. The infamous bus connector that goes bad and stops your charging system from working. I've worked through all of these, but these are all things I'd consider reliability issues that happen really at no fault of mine as I ride it pretty gently. Writing up this list has actually put a lot into perspective for me. The King Quad 300 really is a superb quad. The inclusion of the Super Low range provides stellar engine braking down pretty much any hill you can think of, it seems like it's unmatched. It has great gas mileage, and it's been dead reliable despite being a 1994. It's got 4x4 AND Diff lock, and the semi automatic transmission also help with not letting the quad get out of control down a hill. Plus it's more fun to me and gives me a bit more to do while riding. The biggest annoyance so far has been the parking brake. No matter how much I adjust it, it just doesn't seem stay adjusted after some time. I believe this might just be flawed on these models.  Also, parts availability is not the greatest on these since they don't make anything newer with any similar parts. Front axles are quite expensive, rear drive shafts go for $400 to $500 brand new, etc.
      And that's where the Park gear on Yamaha's Ultramatic eliminates that issue. That's where I keep landing on the older Grizzly or Kodiak 450s. They have a park gear, IRS and Diff lock, a lot of power and they're super fun to ride (got to test one).  But I'd be giving up fuel efficiency and the Super Low range. The Ultramatics still have good engine braking, but still not comparable to the Super Low on Suzuki.
      With ALL that said, curious about what other people out there have had and enjoyed, and I'm just looking to get some ideas of what other smaller/mid sized quads are out there with similar features.  I don't really know anything about Honda, Suzuki, or Arctic Cat models from the mid 2000's.
      Make Model Year Parking (gear/brake) Engine Braking Fuel Efficiency (mpg) IRS Diff Lock Durability (1-5) Reliability (1-5) Overall Rank (1-5) Suzuki King Quad 300 1994 Brake Super Low range 20 Yes Yes 4 4 4 Honda Rancher 350ES 2002 Brake (none?) 17.5 No No 5 5 4 Kawasaki Brute Force 750 2005 Brake KEBC Module 12.5 Yes Yes 4 2 3 Yamaha Grizzly 660 2006 Gear Ultramatic 12.5 Yes Yes 5 5 3 Yamaha Wolverine 450 2009 Gear Ultramatic 17.5 No No 4 5 3 Polaris Scrambler 4x4 4-Stroke 2002 Brake (none?) 14 No AWD 2 4 1 Polaris Sportsman 500 4x4 2000 Brake (none?) 15 Yes AWD 2 4 1
    • Sell your car with CarBrain
    • By Stang
      As noted above!
      I’ve been looking for quite a while now to replace my rip torn CV boots and CV shaft with the axle set up for all four corners.
      I cannot find a company anywhere that sells aftermarket axles
      Also, looking for a new four-wheel-drive actuator switch that bolts to the front differential mine was broken off by a large branch.
      I cannot find anything but OEM parts what gives??
      Again 2024 Kodiak 700 EPS.
