    • By Rick Shropshire
    • By Need-help-with-quads
    • By jashadams
    • By McG75
    • By JakeWens
      I’m pretty sure it’s an 01, that’s what it looks like based on some of the parts I’ve gotten for it already. I’ve been chasing a no spark since I got it, I bypassed the kill switch, I replaced the CDI, the voltage regulator, and the ignition coil. The battery is new, the headlights work so I know there is power leaving the battery. I’m not sure what else to do or check, I’m a heavy equipment mechanic but little a guy gf like this throws me for a loop, any help is definitely appreciated
