My earlier post about creeping forward/reverse when tranny engaged and shifter sticking in reverse and forward has been repaired. I removed the primary clutch and took it to a polaris dealer in kingston on.. It turns out that the brass shims on either side of the ebs bearing are designed to wear out so as not to cause further damage. Mechanic replaced the two shims and also replaced the three weights , as they too were starting to wear into the spiders. Cost was approx. 130.00cad. The belt was riding on the clutch sheave on one side causing the secondary clutch to become engaged. This was affecting the shifting lock-up as well. I also put a belt on the 500 cc that is designed for the 700 cc series. The mech. said it would give better performance and durability. Bike is back to working like a charm
Glad to here u got it fixed..... if ya wanna play u gotta pay
    • By Thekevinjb
      thanks
    • By Coyote251
    • By oxidized_black
    • By Sportsman500guy
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
