04 sportman 500cc creeping forward-SOLVED
roger
My earlier post about creeping forward/reverse when tranny engaged and shifter sticking in reverse and forward has been repaired. I removed the primary clutch and took it to a polaris dealer in kingston on.. It turns out that the brass shims on either side of the ebs bearing are designed to wear out so as not to cause further damage. Mechanic replaced the two shims and also replaced the three weights , as they too were starting to wear into the spiders. Cost was approx. 130.00cad. The belt was riding on the clutch sheave on one side causing the secondary clutch to become engaged. This was affecting the shifting lock-up as well. I also put a belt on the 500 cc that is designed for the 700 cc series. The mech. said it would give better performance and durability. Bike is back to working like a charm
Glad to here u got it fixed..... if ya wanna play u gotta pay
    • By DGBear
      This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
    • By tryn2hrd
      I have a rancher 420 TM that since i bought it has a cold hard shift problem beyond a doubt clutch is not releasing by shift lever. After it gets good and hot it shifts ok. Tried preloading adjustment screw clutch releases and shifts smooth but slips. Have had the clutch out and apart twice for inspection and didnt see anything wrong. Any tips will be appreciated. I've ran out of things to try instead of throwing new parts at it.
    • By oxidized_black
    • By Hagbard
      Have a long story that I'll attempt to make brief. I picked up what was advertised as a 1987 LT230E with no cam or valve cover, harness dangling, no plastics, and all kinds of slop in every bushing and bearing, but hey, it was free and I love a challenge. Local guy had a couple 87 230E motors he was selling on craigslist, picked up one of those and a pisspounded DG RCM and header for $100. Went through the harness to start sorting things out and noticed a few key differences, like the stator connectors didn't mate up, one round and one square. Rubbed some of the grime off and found a VIN, Lo and behold - I have a 1990 LT160E, not a 1987 230E... By the grace of who knows what, the 230 just so happened to mount up directly to the 160 frame with no mods. Wasn't until I had broken the seal on starting to chase down the harness leads that I found out.
      As it stood, advertised as a 1987 230E
      After a bit of elbow grease and some eBay raiding.
      Made a new seat cover and found a set of plastics, New carrier bearings, and brakes all around.
      Pulled the steering and front suspension all apart and gave it some love with new bushings and tie rods
      Ordered a small fortune in NOS and China parts from eBay and RockyMountain and after a couple weeks of wrenching and soldering I have a nearly complete wheeler, in pretty decent shape. Cleaned up a Mikuni carb I had laying around and mounted it up with a cone filter and a Lowe's Racing™ intake boot, and fed it some gas, primed the carb and tugged on the started rope a few times, and sure enough it belkched out some soot and fired up, ran for a couple seconds and died. No sputter, just shut off. Checked for fuel startvation, vacuum in the tank, no problems there, plenty of gas in the carb. Suspected clogged air jets, so I pulled it out of the boot and gave it a shot of ether, and it did the same thing, fired up, ran strong for 2-3 seconds and shut off. Then suspected I f*%#ed up the wiring harness somewhere, and re-traced all the leads with my newly colored wiring diagram, thanks to my kiddo's Crayola marker collection, and everything looked good. Started to suspect the CDI, solenoid, or coil might be faulty and was flipping thru the manual when a buddy stopped by with a pair of boat seats for me to reupholster for him.
      He's a little bit of a savant with engines and electronics, and he got curious when I told him my predicament. Three minutes later he said "Hand me a pair of needlenose?" which he used to short the neutral switch to ground, and had me give it another tug. Fired up and ran great, no shutting off, so we deduced that the neutral switch must be at fault and after he left, I pulled it off to troubleshoot, and decided to flick the shifter a couple times with it off to see the little nubbin go around in a cricle. It didn't. I should mention at this point that I had previously changed the oil and while doing so, I took the opportunity to adjust the clutch without consulting the manual because I'm the dumbest guy I know. I did it according to the procedure I had learned for the LT185 I have, and figured the adjuster itself looked the same, they must be the same thing. I loosened the 10mm lock nut, and started turning the adjsuter screw clockwise waiting to encounter resistance, and then back it off 1/8 turn. I was really surprised when it kept turning and turning, but figured it must have been WAY out of adjustment, and went on with business. Figured I might need clutch plates at some point.
      Encountered this problem, and actually read the manual and the procedure is entirely different, and I realized that I had basically "adjusted" it into oblivion. I have since drained the oil and tried to re-adjust it twice, with no luck. Anyone have any idea what I can or should do to correct the issue, or am I missing something else entirely here? (chain is off and sprocket nut is loose, if that makes any difference.) Any insight or advice would be appreciated, thanks.
    • By n4cer26
      Hi guys!
      I recently acquired a 2004 Sportsman 600 4x4.  It originally ran great but now It runs very rough and only with choke on.  It dies when you hit the throttle. I will be removing the carb for a good cleaning.  At this point I'm thinking it's a fuel issue.  I replaced the fuel pump and fuel filter today as they are cheap.  When I get the carb back we will see how it goes.  If it still runs bad I might try bypassing the fuel pump and running direct from tank to carb.  Any ideas as to what I should be trying would be greatly appreciated.
      Also, the carb has two nipples in the front in the front on each side.  The left side has a vent hose on it but the right side is capped off.  Shouldn't this one be venting as well?  See pic.
      I did pick up a new aftermarket carb to have just in case.  There is a hose fitting on the right rear that my OEM carb doesn't have.  What would this be for?  I would think just keep that on capped? (See pic)
      Thanksnin advance.
