2003 Arctic Cat 400 4x4 gasping at high rpm
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By kevinohio
By Rick Shropshire
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
By 97kingquad
By Need-help-with-quads
