Does Muzzy make an exhaust for the 400Ex? I heard a Muzzy on a 750 grizzly and a KFX700 and the sounded great. I know those bikes are twin cylinders but what a great sound. If Muzzy doesnt make an exhaust for the EX, whats a comparable setup. My white bros slip on doesnt cut it anymore
I would rather know if it would sound good plus free up hp. I would assume it would be a custom build. Ive seen a few muzzy slipons mated to factory ex head pipes sold on ebay but id rather have one thats made for it. Is there another exhaust thatsounds like a muzzy and free up ponies?
Thanks i will email him anyway maybe he could send me in the right direction
Mario We dynoed a ex with a slipon pipe and then we switched out to a full exhaust ! Nice difference in hp gains with full system !!
Does NY have a sound limit ? Colorado has a 96dbl limit so it limits what pipe I bought :no:
I currently have a White Brothers E2 slipon. I am also looking into a 500cc big bore kit and machining.
    • By marlon smith
    • By Olchap
      Thank you,
      Olchap
    • By Louznmemind
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
      My 2004 Yamaha Grizzly 660 seat is a mess, torn up, cracked, and I have been duct taping it for a while.  I bought new vinyl for $35 and need to do it one day. A new seat used to be well over $250 but now its under $100 so I couldn't resist. I got it on ebay with a 10% off coupon for $85.05 plus tax. https://www.ebay.com/itm/146040022154
      In case anyone is looking for a new seat for their Yamaha Grizzly 😁
      I saw it on Amazon as well for under $100
