Is it still winter in Georgia
By Gwbarm
I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
By shorty
First ATV but owned 2 wheel versions all my (long) life. 1990 KLF300C for $500.. doesn't run yet but I'm an old automotive mechanic so not worried. Only a little concerned about the price of parts, certain this antique will need many
By BCNemo
I have a 2001 Yamaha Kodiak 400 (YFM400FWAN©) On a recent hunting trip a problem popped up and I hope someone else has experienced this, so that I can learn from them instead of going on my own hunt for an answer.
The Problem:
On cold days (sub 25 degree) I choke the Kodiak and it starts instantly. It revs up and runs on "high idle" without any problem. However when I return the choke lever to its "normal" position the ATV continues to run and a very high idle. I cant put it into gear until the idle comes down, which it doesn't. In order to use the bike I have to shut it off and when I restart it I must place it into gear before the engine gets a chance to rev up. It then returns to a normal idle and the machine behaves normally. This only happens on real cold days but it is a problem I want to fix. Can anyone offer some help?
