HELP! I would like to add a picture instead for my avatar and add a few more, I cant figure out how to navigate in here, any help would be appreciated :-)
What have you tried so far ? Have you loaded you pics on photobucket yet? For your avitars shrink it !!
Somewhere is a thread on how to post pics !! I`ll try to locate it for you !
Edited by quadnut20
  • Admin locked this topic
    • By Chucksta
      Any ideas?
    • By hporter1208
      Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
    • By Tjp5093
      I'm working on my 02 Honda forman 400 and I have the side case off. I'm trying to see a picture of how the clutch fork and clutch arm on the end of the shifter shaft line up and what direction to face the triangle bearing with the spring.TIA!!!
    • By bobbo
      i currently have a 99 kodiak 400 and a 2021 honda pioneer 1000 and two 110 china atvs  , i have rode atvs for 20+ years and now am starting to fix up some for my kids
    • By Yamess350
      so I bought this raptor from my bubby because it sat in his garage for a year or suck long story short the guy who lost worked on it didn't know what he was doing can just did some of the worst work I've ever laid my eyes on but I recently had the thing running and delt with a lot of problems getting the damn thing to spark need new stator/ cdi and wiring harness and I had finally got the thing to run and drive had a blast omg I love this thing but sometimes I pray it would just stop giving me problems I've road the quad 2-3 time and found there was a huge leak and I took the head off its new btw its black and shiny but the last guy who worked on it did a horrible job and lost parts any ways I fix his mistake and bought oem parts and gaskets but when I when to put the piston back in I could not find a good thread on the orientation on all the rings on the piston and it is a bit confusing how people describe each ring I need a layman's terms like talk to me like I'm slow lol but don't be rude and I need help 1 in the orientation on all the rings and also my engine stopped sucking threw the carb can it be the valve is not seated on intake/exhaust should I reopen the head and redo the rings on the piston or can it be the valve spring gap idk I need help all I know right know is I need a break from the bike and collect information for now can I get some help without people pointing me in all kinds of direction
