why is my 2006 yamaha raptor 350 blowing out the carb instead of sucking
Yamess350
so I bought this raptor from my bubby because it sat in his garage for a year or suck long story short the guy who lost worked on it didn't know what he was doing can just did some of the worst work I've ever laid my eyes on but I recently had the thing running and delt with a lot of problems getting the damn thing to spark need new stator/ cdi and wiring harness and I had finally got the thing to run and drive had a blast omg I love this thing but sometimes I pray it would just stop giving me problems I've road the quad 2-3 time and found there was a huge leak and I took the head off its new btw its black and shiny but the last guy who worked on it did a horrible job and lost parts any ways I fix his mistake and bought oem parts and gaskets but when I when to put the piston back in I could not find a good thread on the orientation on all the rings on the piston and it is a bit confusing how people describe each ring I need a layman's terms like talk to me like I'm slow lol but don't be rude and I need help 1 in the orientation on all the rings and also my engine stopped sucking threw the carb can it be the valve is not seated on intake/exhaust should I reopen the head and redo the rings on the piston or can it be the valve spring gap idk I need help all I know right know is I need a break from the bike and collect information for now can I get some help without people pointing me in all kinds of direction
I had a little trouble following your information, so I simplified your questions to break some possible answers:
1. Put the piston back in.....and ring orientation is a bit confusing....I need layman's terms on the orientation of all the rings
2. My engine stopped sucking through the carb. Can it be the valve is not seated on intake/exhaust? Should I reopen the head and redo the rings on the piston or can it be the valve spring gap?
Answer 1. In general, the most important step is to install the rings facing up or down, ring gap position around the piston is secondary. Rings can have chamfer or a bevel or other features on the inside diameter of the ring to improve performance.....which requires you to install them facing up or down. These are always have a stamped markings in the ring. Follow your installation instructions that come with the new rings. There is usually a mark on the top of the rings if there is an up-facing side. Keep in mind however, I've also seen some rings that don't have a mark, but they are clearly not symmetrical, and that visible difference is how you identify the up-facing side to install them.  Some simple motors don't matter if they're facing up or down, but make sure you follow the directions.
For ring end gap locations in 4-strokes specifically, the simple answer is count the number of rings to install and split them evenly around the piston. This is the simple answer. There are longevity and performance additions to this thought....
The more complicated answer is avoid installing gaps on the exhaust side of the piston. As the piston fires on a compression stroke, the piston's "exhaust side" sees the hardest work and most heat on that side when running, so for longevity, do not leave any end gaps on the exhaust side wall.
Lot's of videos exist on locating gaps....search videos on the web for "4 Stroke Piston Rings From A to Z || Identify, Install and Orient Gaps CORRECTLY!"
Answer 2. Ring end position will not be related to no more vacuum being pulled through the carb. My hunch is your timing chain and Cam are very off, maybe even 180degrees off. Most engines these days are designed with interfering valves meaning if your cam is off 180degrees the Piston will likely clip your valves and break things. If you are seeing the cam gear break or sheared off... or other broken parts, this may have been what happened.
Others may have better suggestions for troubleshooting?
Edited by Matman
Matman is correct about the rings one way to tell is if the ring on the outside edge has a beveled egdge if it is does this beleveled edge goes up otherwise you will have excessive wear on the cylinder wall(if it does not it does not matter which direction goes up this is usually on cheaper engines though). You need to dress the cylinder wall with a cylinder facing hone. This breaks the glase and allows the rings to seat. You will hear of people saying to use gasket maker on the head gasket don't just make sure head and cylinder is clean I use a very fine grit sand papper 1000 grit to clean it. As to #2 yes the intake valve can cause blowback(stop sucking thruogh the carb. If it is adjusted to tight then there will be blowback. Some other thing that can cause blowback is carb running to lean or to rich, timing is off a little and the ignition system having an issue with stator or sensor.
  • 9 months later...
    • By DarkRider
    • By Drillbit
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Sofaspud
    • By Am2007
      Hi everyone,
      owner manual
      service manual
      engine manual
